All kinds of errors in my log
Ktm250
Tomas,
Would you please look at this log and tell me what is going on here. I had no issues with this heli until I upgraded to 1.3.1 and then all this stuff started poping up in the log. The one that gets me is the one that talks about the governor, I don't even have it enabled. I have upgraded two other spirit units with no issues.
spirit-log-2015-10-15-180201.pdf
(92.83 KiB) Downloaded 213 times
ajbwn
Hi im with you on this one, i have flown many different flybarless units and switch the Spirit around 1 year ago, i now have 4 Spirit units on different modals, every time i fly and check the log all i seem to see is errors yet all modals seem to fly fine with no issues, i have tried to resolve the reported errors many times but with no joy, i have now given up checking and just fly them lol.
Good luck Alan
It looks like there are two issues.
Log ends at 4:30. Log was saved because Main Loop Hang Occured.
But then there is another issue, that log was not loaded properly (end of the log) so it displays all possible event messages.
First problem can happen if there is for example excess noise in the power supply, RF noise or static discharges.
In the version 1.3 limits for recognizing this were lowered little bit, but it looks like it is too strict on some helicopters.
So we are deciding whether to put it back.
Second issue should be solved by additional prevent mechanism.
Ktm250
Alan thanks for the input like you stated it seemed to fly just fine.
Tomas, so what you are saying is that there is no real problem and both issues need to be fixed on your end?
It means that there is some noise issue, that should be investigated but it is easy to mask it with the firmware.
But masking any problem can lead to even worse problems, so it is hard to say what is better at the moment.
Ktm250
Ok on the loop hang. Probably has been there from day one but old firmware did not log this level of it. Heli has been flying fine. So what about the second problem with the log not loading properly?
Second issue is what we have to fix in the software. So until you can see all kind of messages, log is correct. At this point you are disconnecting the battery so there should be end of the log instead of this.
