WiFi question
torro
Hi there,
Do you have experience with in flight tuning? i´m talking about fine tuning, not sensor orientation :D
or should the wifi module be switched off during flight?
I hope the WiFi module communicates with 5Ghz?!?
Greets, Flo
Hi Fio,
I recommend to not do any in-flight tuning.
You can accidently change important parameter so it can lead to crash.
Also there can be interference issue - because of this, you can use AutoTurn Off feature.
This will turn off the module during the flight completely. So you will be absolutely safe.
In case of Spirit, you can guess correct values right before the flight. It is possible based on the used components and model.
If you try to find best values, I can try to help you with this.
torro
hi,
ok, thanks.
ChrisTTian667
It may be a cool (security) Feature, when the unit would detect if the helicopter is currently flying (e.g. when esc Signal is > 0%) and then disable such parameters as orientation, servo trimming, ....
cheers ;)
Triabolo|Kosmik 200|XNOVA 4530 XTS|MKS 960/990|Spirit Pro|REX7
Diabolo BE|Kosmik 200|XNOVA 50XX Tareq|REX3
torro
ZeXx86 wrote: In case of Spirit, you can guess correct values right before the flight. It is possible based on the used components and model.
It's time :D
Just installed the spirit in the diabolo 700.
Savox 2271 at the swash, 2283 at the tail.
No gov.
Setup wizard is done. So far no Problems or questions.
torro
Where can i configure WiFi Auto off?
I recommend to set Pirouette Consistency to 185 and Rudder Delay to 0.
Cyclic Gain can be around 60%.
Rudder Frequency 333Hz for tail.
Regarding Wifi module, you can set it at the first page when you connect to the web interface (http://192.168.4.1)
torro
Ok, i'll try.
I used the WiFi only with the Android app, I didn't find it there. I'm gonna connect with a Browser.
Can i use the Browser of the Phone?
Greets, Flo
Yes, you can also use Spirit Settings directly in the web browser without any limitation.
torro
Maiden succesfull :D
Flies very well. Good Job :mrgreen:
