Jeti Integration and ESC Telemetry...
Franky13
Hello!
I use the jeti intigration. Now I would like to connect the ESC telemetry. JivePro and REX6 with the Telem Kontronik cable.
How do I connect them?
Is there an RPM "signal" soon?
greeting
everything is described in our guides :)
Links for them are also directly in our software so if you will just look at the ESC Telemetry, you will find everything needed.
http://manual.spirit-system.com/index.p ... lemetry/de
Franky13
OK thanks!
But the ELE / PIT / AIL slot is occupied with the Jeti intrigation cable ...
Is this no longer required?
It is required, but Jeti integration is using only AIL pin. Kontronik ESC telemetry is using ELE pin. So all can work together.
Franky13
Ok, that was my question.
Now I know, thank you!
HBU
Hallo
I have a new Spirit V2.4.0 via Jeti RSAT2 Ext. and a Jeti Speed Controller SPIN Pro 44 Telemetry on AUX.
Everything works, except Telemetry data from the SPIN.
I just have S Vibs% and S Volt. I was waiting over 10 min. for synchronizing telemetry Values, nothing.
Is it integrated or not?
The Spirit unit does not support Jeti ESCs, since they can be integrated directly with receiver by EX Bus.
So you only have to set correctly ports in the receiver.
HBU
Thanks for the fast response.
In this case, I cannot use RSAT 2. Port Ext. is in use for Spirit. PPM out cannot be configured for channel 1 throttle.
I have to order, at minimum, the new Jeti Duplex REX 3, there I can configure it.
Thanks.
You are right, I have overlooked that you are using RSat.
In this case you will really need at least REX3 with 2 EX ports.
