JETI integration and Telem UNI cable lengths
Malc1
What is the maximum length that these two cables can be without causing any problems?
The Telem UNI cable will need to be connected to an extension coming from the rear of the helicopter.
The Jeti integration cable will need to be approximately double its supplied length.
I will make up a new length cable for this.
We recommend to not exceed 30cm. 50cm should work too. Jeti recommend length as short as possible.
Regarding Telem UNI it is approximately same (can be little bit longer theoretically).
Malc1
Many thanks, I'll will try to keep as short as possible.
As long as I can extend them that will be OK.
