[SOLVED] Binding 4649t and sat to pro unit
Alyon187
Tomas, having some issues with getting the channels to recognize the inputs from the tx. I have the 4649t connected and the sat to the pro unit and srxl selected in the software but none of the channels are moving. The tx says it bound to dsmx 11ms w telemetry but nothing works. Now if i select dsmx in the software it all works as it should but if i disconnect the sat to see if the 4649t would pick up the signal it shows that the rx was loss in the logs. Am i doing something wrong?
You have to select Spektrum DSM2/X receiver type.
What firmware version do you have? If you want to connect it according our Spektrum integration guide, it will not work with official version.
You will need 2.4.3.
Alyon187
Never mind i think i got it. I bound each to the unit using their ootion in the software then switched back to DSMX in the software now everything moves as it should and when i unplug the sat the 4649t still gets the signals and theres no rx signal lost in the logs. Is this correct?
You can just set Spektrum DSM2/X and then bind everything. SPM4649T needs a bind plug for binding but it can be bound separately (anytime).
Alyon187
As always, thanks Tomas for the awesome support! Keep up the great work!
