Spirit and tail motor
cropduster
Hi guys,
is it possible to use a tail motor with the standrad Spirit instead of a pitch tail?
Thx,
Michael
Hi Michael,
yes, you can use it with tail rotor. I recommend to set Pirouette Consistency to 130 first.
But to get the best experience, we recommend to buy uSpirit unit as there the software is specially designed for the tail motors.- once enabled the feature.
The upcoming update will make it even better.
cropduster
ZeXx86 wrote:Hi Michael,
Thanks!! I want to connect an Impeller to build a NOTAR version. How would that work? I connect the ESC for the impeller motor to the rudder channel, right?
Would I need to add another battery for that ESC or can I connect it to the main battery for the main motor? with a V cable?
cropduster
Can I use the uSpirit for 450 size helicopters?
Practically it should work, but since there are higher loads from the servos it is not recommended.
But we tested that it can work reliably also on 500 class helicopter. Our recommendation is for max. 250 class.
cropduster
Ok, I will try to go with my existing Spirit.
Can anyone describe what I need to consider for wiring? So the ESC receiver wire gos into the rudder channel port. The power cables need to be connected to the battery. Question is what I need to consider for powering the ESC, if I can connect the power cables via a v-cable with the same battery that is powering the main ESC/BEC. I understood from another post that I need to cut/remove the +cable in order to avoid two power ables getting into the spirit.
Yes, you can powerup both ESCs from the same battery. If both motors are rated for this voltage.
If both ESCs have internal BEC, you have to disconnect BEC from the weaker ESC. When you will cut or remove red wire from the connector, it will be enough.
Then all should work well.
The only issue is initialization. Because for this, you should have always rudder at minimum - stop signal. But unit is putting Center at the initialization normally. This is thing that uSpirit is doing automatically for you.
With Mix in your transmitter you can achieve similar behavior - When throttle hold is active, you can set Rudder at the position where tail ESC is not spinning.
cropduster
ZeXx86 wrote:Yes, you can powerup both ESCs from the same battery. If both motors are rated for this voltage.
Great info, thanks!!
cropduster
Hey ZeXx86,
I have now installed the fan and connected everytjing to the spirit and it actually works. I have set up a mixer that provides a rudder value so the fan is not spinning at start up. Even gyro is working, so fan reacts accordingly to external influences and brings back the tail.
Now question: What to do with the rudder endpoint (tuning) part of the spirit setup? Where this is quite intuitive for a conventional tail, I don't know what t do with them for the tail motor. Any advice?
Thanks,
Michael
thank you for the info.
You can proceed according the manual - please check this page:
http://manual.spirit-system.com/index.p ... LIMITS_TAB
There in the NOTE for Micro helicopters and µSpirit you can see for what the end-points are.
It is basically the Throttle range for the tail motor. One limit is telling where is 0% (not spinning) and other is for full throttle.
