Throttle and pitch reveresd on transmitter.
keeny
I have a quick question if you use your transmitter with the throttle and pitch in reverse, that's full throttle and pitch with the stick in low position are you still able to set up bailout in the right direction.
Asking for a mate who uses his radio different from the rest of the world :shock:
Cheers, Chris.
urgno
lol you are not alone
i have a friend that fly in mode 3 with reversed tail :o
keeny
Bump ....anybody knows before he commits or not to buy a unit?
Cheers, Chris.
Yes, it is possible to set Bailout. It is not dependent on collective pitch direction at all.
This is only matter of your radio configuration.
In the unit - Diagnostic 100% collective pitch should be displayed when your pitch stick is at the bottom. Normally it is in the opposite direction.
Basically there is no reason why it should not work with any FBL unit.
keeny
All good then cheers.
