Spirit for rotor cycle diameter 1500mm or spirit pro?
lottermann
I bought the spirit for a t-rex 470 some time ago. Can I use the spirit as a stabilizer and gyroscope for a helicopter with paddles and rotor cycle diameter 1500mm or do I need the spirit pro?
regards
Dirk
urgno
spirit (non pro) is suggested till 500-550
it will work well, but we recommend to use Spirit Pro because of more available ports - especially for powering.
So you might need Y-cable to power the unit at least with two BEC cables. But this also depends on receiver you would like to use.
