swashplate moving in wrong direction
rc10tc
I have set up my spirit 2 system for the first time on my trex 600. Everything is moving correctly except the swashplate. When I tilt heli to the left or right, the swash plate does not move correct direction. What setting do I need to change to make it move correctly?
This is the second spirit 2 system that I have set up. The first one I set up on a trex 550e. And I had no issues. The only difference is that on the 600 the system is mounted in the front with the servo wire inputs are facing forward. I set it up forward on the computer set up also. So I'm not sure why the swash is moving the wrong direction.
morrchew
Double check that you have the cyclic and pitch servos set up correctly which would be the left and right servo.
rc10tc
ok, got it to work. Thanks. I thought I could just unplug and swap ch 1 and ch 3 ,but I had to re-do whole set up. So now it works. Thanks!
