well It was working with versions 2.8.0/1.0.3, then I updated to versions 3.0.0/1.1.0 but did not fly it. On the bench it behaved normal, at least in the software.
Then I updated to versions 3.1.0/1.2.0 and run into the described problem.
All those updates were done via WiFi-Link.
The disfunctional GeoLink still sits on the same Heli, it was not pulled off.
When I tested with other Spirits (red one and a Pro) I put those helis next to eachother and used a 50cm JST-JST cable (provided by your shop) to connect components. This way I did not have to disassemble any device.
Hope you have an idea how to fix it!
Regards,
Alexander
