Stabi Correction Parameter
FrankFuss
The description of the new Stabi Correction parameter says that "For models with a high vibration level it is recommended to leave default settings. (Disabled)" . I notice that the 3.1.0 Vibration telemetery has changed and now records a higher level. What vibration level counts as a "high vibration level" with the new Vibration telemetry?
you will see event in the log when vibrations are over 100%.
Stabi Correction is sensitive rather for high frequency vibrations so with a smaller helicopters that are vibrating a lot there can be problem when enabled.
But otherwise this feature can make the rescue even more precise in all other situations.
