Hello friends,
I posted here a few times describing my problems with the setup. Just now I realized what the problem is.
In Australia, where I am - we fly MODE 1. Throttle + Ailrone on the RIGHT stick, Eelevator and Rudder on the left.
For some reason, the SOFTWARE thinks that I am flying MODE 2, so all my stick movements are confused.
How can I fix that?
Spirit setup - wrong flight mode
The Mode you fly in doesn't matter. Use the Channel Sub page in General settings to allocate the correct channel to what the Spirit needs.
You can either change the Tx to match Spirit channel order or change the allocated channels in Spirit settings to match your Tx. Tidier if you change your Tx.
