[SOLVED] srxl2 AR6610T
Neilsteers
I have the Jeti cable plugged into the rudder and pit port from the rx
10x
You will have to put wire with out plug into plug next to the other wire on the el/pi/ai plug
Neilsteers
So to clarify from my srxl2 port on the rx I have the Jeti cable to the spirit 2 and divides into two plugs, one with red and brown cables plug into the rudder port and the other plug with the orange wire goes into the pi/ele/ail port so where should I put the yellow rpm cable from the esc are saying I need to take the plug off and put it in the spare signal pin on the rudder port ?
yufasa
You have to remove the yellow wire out of the plug and put it in the plug that is currently plugged into the ail/pit port making sure it goes into the middle position
10x
HeliMLM wrote:... this is really great news. thx a lot Tomas!
the fix of the failsafe problem with 4651T/Spirit together with the update of the 4651T firmware that should arrive in the next days (fix of RSSI problem on some EU Tx and some other topic) there should be no more problems in fully using SRXL2 hopefully :)
New FW out for 6610t and 4651t and all sorted with RSSI.....
HeliMLM
10x wrote: New FW out for 6610t and 4651t and all sorted with RSSI.....
YESSSS... i've tested yesterday evening and all is fine now with iX12 EU model... 4651t is sending correct dBm and RSSI (display & logs)
cheers
Michael
TD757
I would like to update my Spektrum AR6610T with the latest firmware version. Can I use my existing SPMA3030 USB programmer or do I need to purchase a different one such as the SPMA3060 or SPMA3065?
latjo-k
hi
You need the SPMA3065,the SPMA3030 only works whith AR7200BX.
//Latjo
TD757
How does one update the firmware for the 4651T. I have the 3065 cable and have modified the cable for the 4649T so that it fits the 4651. But it won’t connect to the software. I managed to update the 6610T okay so know the cable and software work. Is the 4651T even able to be firmware updated?
HeliMLM
... the pinout on 4649T and 4651T is different!
cheers
Michael
