How can i change the geolink parameter e.g. altitude limit over lua script.
I did not find the parameters in the basic.lua script
is it possible to change this parameter over bluetooth?
Thanks a lot
Geolink parameter set with lua script
at the moment this parameter can't be configured with Lua script. But we are working on the support.
With Bluetooth module / Android app this is possible
Thanks a lot for your answer.
Do you have any idea how long it will take, 1 week 1 month, 1 year
In the meantime I will connect a BT or a WiFi modul.
Unfortunately you cannot connect both at the same time and I want to measure the vibrations and the other telemetry values in flight.
So i have to toggle the cable til the software can modify the geolink params.
This is only small disadvantage in using the spirit FBL
Thanks a lot your your great FBL /Geolink modul
Ciao
Jörg
Ciao
Jörg
