GT initializing
heri
As I told you, I have the same problem. I use a buffer capacitor to buffer the sevo peaks. I disconnected these buffer, and the problem was gone.Just to think about it.
BR
Heri
10x
I am not using a buffer cap but i am using a Optipower ultra guard....Be interesting to know if HeliMLM is using any thing like this....
HeliMLM
buffer cap (16V 4700uF) is always connected on all of mine, just tried with R2 buffer (smaller one) instead and in both cases no problem with initialisation... but only w/ YGE bec, i cannot easily repeat the test w/ a lipo.
cheers
Michael
10x
HeliMLM wrote:Hi,
Thanks for that Michael...Just disconnected the Ultra guard to see but no difference, still needs the double connection....
10x
Hello Tomas
Still getting this fault, here is a log taken today after problem...
Picture attached....Hope this will help...
Regards Adrian
Dr.Fleming
heri wrote:As I told you, I have the same problem. I use a buffer capacitor to buffer the sevo peaks. I disconnected these buffer, and the problem was gone.Just to think about it.
BR
Heri
I use 1ST Buffer connected to the "GT" AUX 2 on all my Heli's, no problems.
heri
Hello, the problem reappeared. So it looks like the buffer was not the problem. But, when I look at the picture of the log, maybe it is a problem with the voltage. At the second try, the unit is preloaded and voila it starts. It is just a guess of me.
Heri
10x
I have been trying different things but still does it...
Can you try to turn off RealTime logging only for verification if it makes some difference please?
10x
Hello Tomas
Should the real time logging menu be in the jeti intergration under diagnostics? as i can not find it on the jeti but it is there on the pc setup...
