I mean F.Port, FBus is not supported with any Spirit unit yet.
F.Port was supported only with Spirit GT until now.
FrSky Integration with Ethos, S.Port & F.Port
We also made small improvement for S.Port that will help ACCESS operation. But integration support with EthOS and S.Port can't be enabled by us in any case.
Now together with FrSky we were able to resolve issue that was present with some ACCESS receivers for long time with a random loss of sensors.
tysonfromcanada
I'd like to give that a try - I have a heli I'm setting up now with a spirit 2, x4rsb (can run f.port firmware) and the integration cable that I can test it out on - currently control + telemetry is working via sbus+s.port and so it won't take much to switch it over and try it out. I also have an rx4r-access that I can try it out with.ZeXx86 wrote:If someone is interested we have working F.Port on all Spirit 2, Pro, micro with FrSky integration cable.
So telemetry and integration will work also there from now with OpenTX, EdgeTX and EthOS.
Thanks,
Tyson
Dudemeister
So, I assume this is happening as of version 3.4.4 of the Spirit firmware. Perhaps a bullet point should be added to the description, because when I first read it, there was no mention of this.
This is not included in 3.4.4, but 3.4.5 that we are working on.
Dudemeister
OK, so maybe you should have said that, because the way you said it (we have working F.Port on all Spirit 2, Pro, micro with FrSky integration cable), it sounds like it's working right now, and some people might have already flashed their receivers to F.Port only to find nothing works right now.ZeXx86 wrote:This is not included in 3.4.4, but 3.4.5 that we are working on.
It is working now. For this reason I said that anyone can tell me and we can provide this firmware.
