I haven't used my bluetooth module for a while, but I have a newly set up heli and thought I'd check the bluetooth out in case I need it at the field.
I can connect and look at a few menus (but never the general tab) but get the following errors, then it drops the connection.
'Damaged profile' and 'firmware version unknown'.
Is my Bluetooth unit faulty, or does it not work with the latest software?
The FBL work fine with the USB connection.
Thanks.
[SOLVED] Bluetooth on V3.6.1
Please make sure to set directory in the App settings for saving the logs first.
New Android app was released today on Play.
It could be needed to assign permission to Application for storage access.ianboom wrote:How do I do that?
I've selected settings, then storage directory and get an error.
Hi.
Still no luck.
If I go straight into settings and select storage directory, it comes up with the same error above.
If I connect to the spirit unit and then go into settings it reverts back to the main menu page.
If I go into diagnostic then log viewer, it says first select a directory and when I select the storage directory it either reverts back to the main menu page or comes up with the error above again. With either result, it disconnects from the spirit unit!
What is the end of the tab 'save settings to u..' on the settings tab?
Still no luck.
Save Settings to u... mean Save Settings to Spirit unit. This will save settings to the unit in the same way as with PC software.
