Ethos 1.5.8 update / Spirit Ethos integration
Thanks a lot! This is great idea.
Maybe you can contact https://github.com/bsongis-frsky for information exchange.
I can imagine that the problem is fixed in the nightly
https://github.com/FrSkyRC/ETHOS-Feedba ... /nightly15
- [lua] Fix for sensor:stringValue() if the sensor is a TextSensor
another user on Github has tested the nightly version 1.5.10 with no success !
Tomas I think it will be necessary that you or your team test your integration sript and give the developers on github response which errors occur when the script fails so that the problem with the integration in ETHOS can be solved - we as users have no options and I read there that the developers are willing of help if Spirit contacts them, so I think that is our only chance for a smooth running integration on ETHOS-
Thank you in advance!
Matthias
Matthias
we resolved the problem in the new Lua script.
It will be available for download likely from tomorrow.
FrSky changed behavior of Lua interface from previous version. So the script will not work on older EthOS versions from now because of this.
mainstreet
1.5.9 doesn't work with the lua script either
Yes, it cant work. Many Lua scripts are broken since 1.5.7.
Hello Tomas,
great to hear that the scipt will work again !
Thank's to you and your team !
Some functions in LUA are now marked as depreciated as you can see on github and I think this will change from time to time again that the script won't work and has to be changed...unfortunately -
Perhaps a suggestion regarding the LUA scripts, one could refer to using the LUA script version 3.5.0 revision 2 up to ETHOS version 1.5.7 and offer it for download, that can remain unchanged and then use the most current script, which for example only works from ETHOS 1.5.8 onwards - This would also take into account users who do not want/cannot upgrade to the latest versions -
Best Regards
Matthias
Best Regards
Matthias
