Gaui X3 - UPDATED
Jman841
Gaui X3
ZEAL 350mm Main blades
Zeal 62mm tail blades
Xnova 2618-1860kv
13 degree's of pitch
Hobbywing Platinum V3 50amp ESC
TGY 306G HV's all around on 6v
Flight style is 3D and Hard 3D
Bank 1: Sport and Smooth 3D
Bank 2: 3D and Hard 3D
Bank 3: 4s setup run at 2400 rpm
Enjoy!
Gaui X3 Settings.4ds
(255 Bytes) Downloaded 245 times
zorem
I am going build Gaui X3 these days.
Do you have Spirit FBL instaled with servocable forward or backward ?
I would like use your setup. Thanks.
Jman841
Sorry for the late reply. Just saw this. Currently cables are to the rear of the heli.
I have changed a lot since that intial setup and tuned my X3 much more. I am very pleased with how it is setup now.
Bank 1: Sport and 3D flying
Bank 2: 3D and Hard 3D flying (my most used bank)
Bank 3: 4s setup for low HS flying (at 2400 rpm)
(I updated the main post as well, both are the same file)
(255 Bytes) Downloaded 243 times
Bjoern_ve
HI,
I am very interested in your setup because I have problems with my tail. It begins to tremble at backward flight and I'm not sure at what setting should I turn. My head speeds are 2600-3000 rpm.
When I look at your setup to me then I see no difference between the individual banks, can you tell me where the differences are?
Can you maybe give me a few tips?
Setup:
3x TGY306 on Head
1x TGY306 on Tail on 6V
Align 460MX on 6s on 6V
ESC Castle Phoenix ICE 50
Blade:Align 360
Tailblade: Align 68mm
on the Tail is the belt upgrade
Björn
Gaui X3, Gaui X7
What is the length of ball linkage on the rudder servo horn? I recommend the closest hole. Very important is also Piro Consistency parameter.
Bjoern_ve
I now have the linkage so transformed that I use the first hole. However, I now have the problem that the tail no longer holds in high pitch and it turns away about 90 °.
It then appears in the log message on the Rudder Limits reached. I'm going to experiment with the distance of the linkage and so try the best results achieved.
Are there any other tip I could try?
Björn
Gaui X3, Gaui X7
make sure that you have readjusted rudder end points and that your gyro gain is configured properly.
scrambled
If anyone is interested, my X3 settings with (regular) Spirit v1.3.2
Spirit rescue and governor is in use. :mrgreen:
- Belted tail
- HW50A v3
- Align (6S) 460MX dominator motor
- 3x KST DS215MG
- KST BLS505X
- Align 360mm CF mainblades
- Align 68mm plastic tailblades
X3-Rescue_governor_2-1.3.2.4ds
Bank2
(255 Bytes) Downloaded 186 times
X3-Rescue_governor_1-1.3.2.4ds
Bank1
(255 Bytes) Downloaded 181 times
X3-Rescue_governor_0-1.3.2.4ds
Bank0
(255 Bytes) Downloaded 182 times
