Spektrum SRXL and failsafe problem
Pitch should not be changed at all. This is intended behavior.
The problem is, that receiver is not transmitting failsafe data to the unit at all, so the unit is using its own pre-configured. I will check how it is possible with Spektrum to transmit failsafe over SRXL - it should be only matter of transmitter configuration.
Helmet
Ok. But the unit does center pitch when signal is lost, using sats-only. I believe it should act the same way when SRXL is used. Full pitch on a heli that has lost contact with its transmitter is a bad situation.
SRXL and satellite transmission is very different. In case of directly connected satellites failsafe is stored directly in the unit, because there is no receiver. So it is only option that can be applied in this case (satellite has no memory for failsafe).
If there is receiver, failsafe should be stored always there.
Jeti with SRXL behaves in the very same way in default settings, so that failsafe values are not transmitted to the unit. But it can be changed in the receiver settings.
Helmet
Ok, I understand. Pre-set fail safe positions are not transfered to the gyro via SRXL. Tested and confirmed. That's not good. Is it possible to set fail safe positions in the software in any way, still using SRXL? Cyclic goes to neutral position if signal is lost, and I want pitch to do the same. Or do I have to use sats-only or cable-looms to achieve that?
