Setting up spirit gov with hobbywing esc
Alyon187
when i tested the high side throttle i ran the motor up to full speed w the throttle curve set 0-100 and could increase the high side end point in the spirit software and I could hear the rpm increase. Should I increase this until the rpm stops increasing? Im also getting a nasty kick on my 500 when I flip out of throttle hold. Ive got the hw set to airplane mode and end points in the software at -100 to 100, already did the throttle calibration before activating the spirit gov and throttle end points in the gov section set to 1100 and 1940 (according to the hw user manual) but like I said when I put throttle curve at 0-100 and put the throttle at 100 I can raise the high side throttle in the gov software and hear the rpm increase. Is this right or should I increase the high side til the throttle stops increasing? And how can I get rid of the kick? I tried lowering the ramp up but I get a delay before I get to a point where the kick is gone.
Coco66
I hink I remember reading that you should not play with Min and Max with Governor on.
Don't know why, though.
I would try the same, to see if you can get Max higher, but without Governor active.
