DX9 set up no sats no gov
bill rob
Ive just noticed that on monitor screen I have gyro 64 but when I rescue it goes to -66..when I had the software up it was even IE -100..100 matched ok,,does 2% matter if its ok on software?
jgiannakas
bill rob wrote:Ive just noticed that on monitor screen I have gyro 64 but when I rescue it goes to -66..when I had the software up it was even IE -100..100 matched ok,,does 2% matter if its ok on software?
Nah it makes no difference at all. I do think that you should lower your gyro gain to something like 55-60 for your first flights to make sure the tail does not wag itself to death. If you need you can increase post your maiden.
bill rob
Ok will do,thanks again for your help
Alyon187
Just drop one of your mixes bu two points. So instead of 100/-100, use 100/-98. Mine was off my one point for some reason so I did this and it fixed it. But two points really isnt that big of a deal.
bill rob
Hi,ive decided to use a satellite,so dsmx2 connection,if I use satellite with no gov,do I need the second mix?,,also should I have throttle from esc plugged into AUX?
Also on diag screen on software my ele only moves the green slider to +50% and -50%...any idea how to get it to 100%,,when I use full servo travel I can get it to 75% plus and minus.
