New 2.3.0 release in a MZ18 Graupner
Thank you very much.
We are working on the solution.
Sorry for the troubles.
Windsurfer1976
It`s not a big problem for me. But would be fine, if u can find a solution.
Greetings Andreas
I hope that solution will be available tommorow.
nenno
ZeXx86 wrote:This is interesting, because TomasN is running Unisens-E and Spirit together with apparently no issue.
So maybe there is something that is doing the problem.
Can you try to reconfigure Unisens-E to EAM?
Already tried that. Same Problem
I updated the Unisens too. No changes.
Nenno
Voodoo 600 - Compass Warp 360 - Mikado Logo 480xxtreme - FrSky Horus X10S express
the firmware that should solve the problem is available here:
http://spirit-system.com/dl/fw/spirit-fw-2.3.1.4df
Can you please verify that the problem is solved with this?
You do not have to change anything in the settings, only flash it.
In our tests it is looking well.
nenno
ZeXx86 wrote: Can you please verify that the problem is solved with this?
Hi...
... It works now !!!
I tested it with a Unisens-E in ESC-Mode and EAM-Mode. Works perfectly.
Thank's again for your quick help!!!
Regards - Nenno
thank you very much!
We have released the firmware officially now.
neeno: I recommend to re-download it and flash again.
Windsurfer1976
Works great now. Thanks a lot. That was fast :D
Can u tell what is the Vibration-Level in GAM? For example Fuel "100" what does it mean? 100% Vibration Level max on the most vibrating axis?
Yes, Fuel and Height in the GAM. Vibrations are in %.
Thank you very much!
Windsurfer1976
Height is always 0-2 meters, fuel always 100. Is this correct this way?
Seems to stay the same all time. Fuel seems to be fix and height changes all the time between 0 and 2
