Chronos tilts at low rpm via nick and roll
sascha1603
Have everything set correctly
Swash plate runs clean evenly
Can imagine with only the head gyratory
Greeting sascha
cycled
Maybe your radio TX has some mix active when "bank 0" is selected?
sascha1603
No, no mixer active
Also in the diagnosis no change when the banks are switched
Had such a problem times with the Bavarian Demon 3SX and it was the head gyro
Just should I up or down? With us is currently the weather so bad the fly is not possible
Will make a video if the weather is better
Greeting sascha
sascha1603
Pity the otherwise no answer came what else I could try
I am sorry, but I am very busy at these days.
Yes, you can increase Cyclic Gain. Usually you can go over 60%, but some helicopters can fly even with 90%. Especially low RPM might require higher gain.
If absolutely everything is correct, then the problem might be only caused by very unequal CG (your helicopter is very heavy for some side). By putting batteries in other position it might be OK.
We have other pilots with Chronos for long time, but nobody had such issue. So I believe it will be just something basic.
sascha1603
Thank you for your quick response
I'm going to go 90 times, the complete electronics is equal to my 7HV converted, batteries at the same place
Only the weather is so bad that you can not fly
Much it can not be :-D
greeting
