[SOLVED] Stability mode
Great, yes to the same direction as it drifts. You should see the difference.
john1127
So if it drifts forward and to right, Move battery forward and to right.? john thks
john1127
please answer ,it seems opposite,
Oh, if you can see it is helping in the opposite way it is the correct solution. You should see the difference when you are changing CG.
So if possible, you can change CG so it is very stable.
