uSpirit + Geolink problem
uSpirit is using internal oscillator always, so you will see the event always. But that is all correct with uSpirit. But it is not correct to see with Spirit and Spirit Pro units.
I will check the logs and configuration. Unfortunately it is very hard to find the problem since it can't be replicated with any of our helicopters where it is working perfectly always and with any unit. All the features were tested for months with hundreds of pilots around the world. But we are working hard to find the problem in your case.
Xform
That is very interesting it worked perfectly for you in Czech Republic. Does this have to do with the United States and its magnetic field differences? Thanks for helping us. I am sure you will get this fixed. Altitude limit (hard deck) is mostly working, but it still has the problem misjudging the altitude sometimes activating too high, then too low. However, this is a big step in the right direction for GPS. There will be a time when we do have an uncrashable heli.
urgno
Xform wrote:That is very interesting it worked perfectly for you in Czech Republic. Does this have to do with the United States and its magnetic field differences?
thats why you have to re-calibrate the unit before using it ;)
Pking
I did recalibrate the unit more then once.
Envoyé de mon iPad en utilisant Tapatalk
urgno
then maybe there is a strong magnetic field next where you fly
Xform
I recalibrated my Geolink many times. Interestingly, when I go home and view the geolink map, the geolink shows exactly where I am and it is very accurate. It just has problems while flying, but otherwise, it shows my location on the map really precisely.
I was thinking maybe something different about the Czech republic makes the geolink work better there? I don't know.
urgno
maybe is that i am not so far like you from czech
