OpenTx integation does not work
denis747
It looks like it is the receivers wifh redundancy bus that are affected by this then. They might be running a slightly different firmware and that might be the reason I think.
Sent from my SM-G950F using Tapatalk
Sadly we have still not received any reply from FrSky regarding this issue.
denis747
Tomas, I will send them a message on RcGroups and I will link them here. I think they have an active representative on RcGroups.
denis747
Hi Tomas, a Frsky rep replied on RcGroups. He said they have noticed the problem and will give a reply as soon as possible https://www.rcgroups.com/forums/showthr ... st41081627
Thank you for the message.
We will urge the issue directly in FrSky once again.
Today FrSky received our unit for testing and in no time they have managed to perform the tests.
And results - It is working perfectly with RX8R receiver and Taranis Q X7.
They have sent video from the testing and it just works.
They were using OpenTX 2.2.3. Next week they will be performing tests with X12s. Can you confirm that it does not work with this version for you?
duckforeman
I will try it this evening or tomorrow morning with the receivers I have. I think I was running Open TX 2.2.3 when I tried it before, but will make sure. I'll also make sure I have the latest receiver firmware.
Using Horus X10.
Carthago
Hello Tomáš,
I have done a quick test using my 12x with OpenTx 2.2.3 and I cannot see any difference in behavior than before.
Lua scrips only work when starting them first and then power up the heli.
Regards,
Toni
Carthago
Addition:
When I start Lua first, Spirit LED keeps on blinking even if I escape the scrips screens.
denis747
ZeXx86 wrote:Today FrSky received our unit for testing and in no time they have managed to perform the tests.
Tomas, it only works if you start the lua script first then connect the integration cable then power on the FBL. If you, first, power on the FBL with the integration cable connected to the rx8r pro, the red LED on the Spirit Pro just keeps on blinking and when you start the lua on the Qx7s nothing loads on the lua script fields. The LED on the Spirit Pro will stay on blinking until you disconnect the integration cable.
I will make a video of the issue when I get home later today. For now I fly the heli with the integration cable disconnected as if you leave it connected, the LED on the Spirit Pro just continues blinking after you power the heli on. Even if you exit the lua script, the LED on the Spirit just keeps on blinking and continues to blink. The only way to stop it blinking is to power it off, disconnect the integration cable then power on with the integration cable disconnected.
