T-Rex 700 V2 Tail wags
I asked because it is default settings for VBar so the most pilots is using it. Unfortunately you might not notice if mechanics is not smooth anymore and servo load is increasing a lot more. So we recommend to not use Revomix, since it shouldn't be needed with any good servo with a similar models.
Matzer27
Is there revo mix in open tx?
It is available in the Spirit unit - Advanced tab. But we do not recommend to use it if the tail servo is fast enough. For the most todays model it shouldn't be needed.
Value of 3-4 should be fine.
