Yes it's there and I use it. But this is RPM of the motor. As soon as you hit throttle hold, the rotor head keeps spinning, but the motor stops immediately (because of auto rotation bearing) and this becomes 0 RPM, and this is what Spirit gets. So if you bailout, Spirit starts - for example - 3 seconds spool up from 0 to 2200 RPM, so if your rotor head already has 1100 RPM you get 1,5 seconds delay until spool up gets to this speed. At least this is what I think might be happening...jjuk wrote:There is an PRM output on the HW escs, plug that into the Spirit so it knows the RPM. The RPM can be seen on the gov setup screen in the spirit setup software, and you can test gov on the bench.
Let me know if you get it working, because i'm completely stuck and can't get bailout to spool up fast enough.
If I use bailout in the HW governor, it bails out immediatly. Not sure how it's doing it.
