[SOLVED] Assigning Bank to channel 7 using PWM receiver?
toto_gt
hi @ all,
anyone here who know how to archive this with a hitec aurora 9 with optima 7 rx ?
i can't set negative values in the aurora ! so i am not able to switch.
cheers
I think you can use PPM with this receiver so you can use all 7 channels.
With PWM you can use Banks in the way that Gyro function is unassigned and gain is configured via software.
Banks function should be assigned to Channel 5 so you can switch Banks with Gyro switch in your transmitter.
toto_gt
thanks for your answer , but hitec has no usable ppm reciver. they start using them with the aurora 9X which i dont own.
so i changed ch 5 to banks and programmed a 3 way switch on the aurora.
pos. 1 bank0 disabeld
pos. 2 bank1 stabilisation
pos. 3 bank2 rescue normal
in the diagnostic i can see that the switch does change the banks, but nothing happens. if i switch i.e. for rescue normal.
the swash plate does not move at all.
any ideas ?
thank you !
you must set your Gyro gain to minus values, for example -60% if selected function should be activated.
It is same as if the gain is configured in your transmitter.
