setup problem
The Mechanic
I would like an exchange actually as most people really like the Spirit and I think I will too. I do trust you and tried all your suggestions but as I said I don't use DSM2; it should work fine with DSMX. Please give me the return address you would like shipped to.
OK, you should receive private message.
Address is also mentioned on the box of the unit.
The Mechanic
Oh, and I was going to ask, maybe you missed in previous post; is it true that all ports except ELE/PIT/AIL and SYS share negative and positive bus? You should be able to plug 5V power into any port except ELE/PIT/AIL and SYS?
Yes, it is true.
The Mechanic
Thanks!
Yak
Have you tried filming the TX (with the channel outputs) and the diag screen.
The guys here really helped when I and another user ran across something very weird.
Have you a full RX (not sat) that you could connect with the loom to test.
Cheers,
Yak.
