Rpm Hobbywing 60 amp and Oxy3 Hovering (Solved)
Yes, this is correct, because Governor is holding the RPM regardless load but without governor you will set power directly. Especially without main blades it can be too fast.
Pino74
in fact I disabled the governor from a bank without blades:) and the rpms were very strong,
I think in the flight with the blades there will be more inertia and maybe even dangerous, maybe a bailout.ma won't do it.
I don't see the sense of disabling the governor in flight. It was only my own.
