Device Explorer - REX-RS settings not available
Till
Thank you :D
Rouven
I have copied the previously provided files to the "Devices" directory and the configuration is now also available with pictures. Nevertheless I have still a problem with the telemetrie port E2 (outermost left connection port, lowest pin), it does not transmit any telemetrie data. When I connect the same sensor to E1, it works. It also works when I connect the sensor to EXT (outermost left connection port, upper pin), but then the Spirit RS cannot be accessed anymore via the device manager.
Unfortunately I cannot configure port E2 in the device manager and require port E1 already for backup power device.
Maybe anybody could give me short instructions how to fix it.
Thank you and best regards,
Rouven
port E2 shouldn't be used. This is only for special purposes, please see Spirit RS guide:
Instead you should use EXT or E1 port. More details in the guide.
Rouven
Thank you for your quick response.
I think I have already used EXT port. The signal pin of the sensor has been connected to the "EXT/RPM/E2" port to the lowest pin, as described in your manual. Unfortunately it doesn't work...
Regards,
Rouven
For sure it will work, possibly the sensor was not powered from the same power source or from a correct port.
This might be reason why it does not work.
Rouven
No it doesn't work. I change only one single pin from port "EXT/RPM/E2" lowest pin to "E1" topmost pin and it works...
Can you tell me what type of sensor it is?
Rouven
It is a Kontronik KOLIBRI 90 LV and set to Jeti telemetry.
Ah, it is likely this require EX BUS protocol. But EXT port is configured for JETIBOX/Sensor.
This is reason why it is not working, because EXT port is only for standard sensors.
On the other hand you can connect your ESC with Spirit ESC telemetry at the SAT port.
Rouven
Thank you for the quick response.
Yes it uses EXBus, since E1 is configured to that and it works...
So I use an alternate connection setting.
Thank you for your help!!
