Spirit Profile Viewer / Zobrazení profilu
Ahoj,
mohu, ale tak ci tak ho nedoporucuji pouzit. Jakykoli profil z jine heli by se mel pouzit spise jen k nahlednuti. Pokud je heli osazena stejne a je uplne stejne mechanicky nastavena, pak se da pouzit. I tak vice nez 3 hodnoty parametru nema cenu "okopirovat", ostatni uz jsou veci, ktere ma kazdy trochu jinak.
Jakmile je ale nekde jine servo, muze byt nastaveni uplne jine a poleti to spatne.
Spise je lepsi napsat, co zlobi a poslat tve nastaveni.
U Protose to byva vetsinou vrtulka. Nejcasteji je problem v mechanice - nejde tak jak by mela (i kdyz je heli treba uplne nova). S protosem mam hodne zkusenosti, takze mohu pomoci.
IvoR1
Díky za odpověď, přiložil jsem své profily http://www.spirit-system.com/phpBB3/vie ... 371#p13371
Koukni prosím na to.
Díky
Protos,Agile 5.5,T14SG.....
Adrian
reports unsupported for version 2.4
stefaanbolle
I am using a Spirit Pro with Geolink and an SRXL2 4651T receiver.When uploading the 4ds file on the profile viewer beta webpage, I get belo error:
Code: Select all
index receiver_values and value 6 not found
Is SRXL2 not yet supported?
stefaanbolle
Is there a problem with reading the file when using a SRXL2 type receiver? Where do I have to report a possible bug?
Thanks!
we will try to sort it during next week. Thank you for your patience. Unfortunately we are still extremely busy.
stefaanbolle
No problem!
Thank you very much for all the great work!
MichaMEG
unfortunately, this no longer works with the current version.
The following message appears:
Unsupported version: heli-3.2.1
I would be happy if you would update the tool!
Thank you very much
Micha
chinook
Error still shows, any chance you can fix this?
we will make completely new viewer. It will work with all versions without error.
