Spirit Pro
Everything is described here if one want Spektrum Integration:
But for normal flying it is not needed.
alex4orly
yufasa wrote:Highly recommend using the USB cable the first time and is needed anyway unless you have Jeti radio and RS receiver.
Integration is cool but more something that you use at the field to fine tune your heli rather than set it up the first time. (Again, unless you have the new DS12 Jeti that has the wizard built in..)
I have a few videos’ that will walk you through the process. Just look at my Spirit playlist here:
https://www.youtube.com/playlist?list=P ... 6h2VNbHPOz
Hello Yufasa,
I watched the 1,2,3 videos - very good job, thanks for sharing.
At the end of part 3, you say there will be more videos on Advanced settings, I can't find that?
Cheers
Yesterday is history, Today is a present, Tomorrow... a dream.
alex4orly
jjuk wrote:He means what tx/rx can be used with transmitter integration setup.
Hi Juuk,
I am using a Spektrum DX9 Black Tx and just purchased - SPM4651T Spektrum SRXL2 Remote Serial Receiver following the details in the forum that this will be OK.
I read the manual and the Integration section. There are several comments I have, but mainly:
1) Until reading this chapter, I didn't know that I will need a special cable to connect it to the Spirit.
2) In that chapter, there are several things unclear to me (being new to RC Helicopters) - I will no doubt need the forum help once I get the Sprit and start the setup. I will note, it is my own problem, but I have noone around me to assist me with this.
3) In that chapter, I found something towards the end, saying a step I need to do before all that. Maybe, it should be moved to the start of that chapter.
Thank you all for any help
Cheers
