Posting problems
urgno
when you have some attached files
the button has to be there
if not, you are doin something wrong in the attachment process
maybe go give a look to attachment management in your user control panel
latjo-k
HI
maybe you have reached the total quota of attached files.In that case you have delet som in your
user control panel.
//Latjo
It is enough to click at three buttons in total.
First select file, then add the file as attachment and then confirm the post.
Anyway if there is some problem you have to see some error. Otherwise you just missing to click at the buttons.
alex4orly
ZeXx86 wrote:It is enough to click at three buttons in total.
Hello all, Yes - I was doing something WRONG... Will see if I figured it out
I added step-2 of the wizard. My elevator connector is at the front, but when I pick the model to Trex-600, it shows the swashplate with CH-2 at the back, why?
I reset the unnit to factory, I have NO reversing on the Tx, I have no reversing on the unit.
All my stick directions are correct, including the tail / rudder.
The only thing I can't get is the 6 degrees, I can get as close as 8.2 degrees. Does this indicate that my swashplate is sitting too high?
Yesterday is history, Today is a present, Tomorrow... a dream.
azaz44
I think you need to explicitly subscribe to the topic to get emails. It doesn't auto subscribe from the topics you created (I wish it would).
And of course check your spam folder..
urgno
azaz44 wrote:It doesn't auto subscribe from the topics you created (I wish it would).
it does :)
just go in your "user control panel" -> Edit posting defaults
and enable: Notify me upon replies by default
azaz44
it does :)
That's good to know, I have the right settings now :)
urgno
glad to help ;)
