Problems changing from Spektrum DSMX satellite to SPM4651T
cracked canopy
larspe wrote:Updated sw of the receiver to latest version. Still doesn't work.
Just to confirm. I am connecting my single spektrum spm4651T to the spirit pro directly using this cable:
Should I be using this cable instead (dont have...)?
https://store.spirit-system.com/en/acce ... cable.html
Thanks again for any assistance.
You should be using this cable.
larspe
Which cable? :-)
larspe
PROBLEM SOLVED! :-)
Turns out that the cable needed to connec a single SPM4651T to a Spirit Pro is the following:
The other cable sold doesn’t work. I would like to understand the purpose of the 4 pin to 3 pin cable if anyone from Spirit would like to respond.
HeliMLM
... the other cable sold is for connecting ADDITIONAL srxl2 sats... not for the main one, if i understood correctly?
cheers
Michael
larspe
HeliMLM wrote:... the other cable sold is for connecting ADDITIONAL srxl2 sats... not for the main one, if i understood correctly?
If so, that should me made clear in the documentation!
cracked canopy
In the SRXL2 section of the manual 1.2 shows the correct cable to use for the SPM4650T, SPM4651T, SPM9747
Satellite would work, but there must be always srxl2 receiver in the ail/rud port.
