Spirit GT , Function "Rescue normal" issues
If I understand it correctly, you can see also other problem with rescue changing angle - later after few minutes it does not work correctly, right?
If this is the case, you can check this page:
Dr.Fleming
ZeXx86 wrote:Hello,
it is not possible to set Rescue (Automatic) to run in background while using other Stabi mode at the same time.
This is possible only with GeoLink Altitude Limit - you will enable F: GeoLink Altitude Limit in the General/Channels with assigned channel.
No need to use Bank Switching at all.
Good morning thanks for the reply, as you can see ( Youtube) this user make it works with his Jeti Transmitter,
also it is not a "GT" Hardware problem, it is a Software Design problem.
https://www.youtube.com/watch?v=TLPrb8yV0Qo
You can change between Rescue modes or Stabilisation modes with only one switch.
It is enough to set Sensor/Rudder Gain to a negative value for stabi function.
Then even 6 channel radio is enough. Settings is same for all Spirit units.
Dr.Fleming
ZeXx86 wrote:You can change between Rescue modes or Stabilisation modes with only one switch.
Please add the basic function "Rescue Normal" in the channel selection window P:
then it is possible.
There is so many function to chose in this window, that normally not need most of them.
Not need ruder gain, for user with transmiters and enough channels .
