Short shaking after taking off with connected Geolink
NitroRex
Whoever has new software online, always has a new label? So that the difference can be seen.
For anyone interested in testing the new firmware please let me know.
It should fix the issue with short shaking when GeoLink support is enabled, is changing Automatic Rescue for new behavior, eliminates swashplate movement when model is on the ground while Position Hold is engaged and few other improvements.
kumpelblase_2
I'd like to test it.
Tgalo
I would also not mind beta testing
Helipilot
I would like to try the updated firmware as well, thanks.
Lee Jordan
I have the exact problem as described in the original post.
Spirit GT + G.L
Just after takeoff, it has few seconds of shaking. after they are gone, heli flies very nice for the entire flight.
In my case, there was one flight where I didn't wait for this shaking to go away and took off quite hard ( Tareq style),
the heli entered a very hard oscillation/shaking and crashed.
Hope to see it solved soon.
New firmware is about to release likely on monday.
There are many smaller or bigger improvements basically for all units.
kumpelblase_2
Made two flights today with the new firmware and there is no more shaking. Tested the rescue function as well as position hold and attitude hold which worked fine.
Lee Jordan
This is good to know :)
Will update the firmware asap.
Sent from my Redmi Note 8 Pro using Tapatalk
Storchy
Make three flights today, no more shaking
Thank you for 3.3.3
Good work
I testet also HoldPosition, very good, stands still on the place, only increasing a litte the altitude level but very smooth
