es zuckt nur ein Servo beim Initialisieren
Till
Thank you - that was very helpful. What means "you have always view the log to get normal initialization" - is it enough to look via the integration menu (what I do) or is it necessary to look through the pc-software to clear the error-memory ?
So I have the Spirit RS, the unit (reciever and fbl-unit) should turn off at the same time and i wait for the connection lost message before I turn of the radio.
So I will investigate this further - what makes me a little suspicious that with my other RS units no problems arise with almost the same equipment..
All models should be always turned off so that first battery from model is plugged off. Then radio is turned off.
If it is done in opposite way then this error message will be generated and saved in the log.
Logs must be viewed with PC software to clear the error message.
