Spektrum NX6, NX8, NX10?
Hello Tomas !
Thanks a lot for your answer ! I am very happy to say it works flawlessly ! :D
I had the last firmware, but I probably made a mistake myself - right after reading your answer I rushed into the basement and tried it out and what can I say, it worked without any problems! The whole point for me was to hold the two sticks in the respective corners and roll the roller to the right, because I didn't do that before, I just held the sticks in the corners and waited for a window to open ...
Once again, thank you very much for your help and great support!
Many greetings
Matthias
Dennis P
Quote !!
So happy I found this thread. I have read and reread the integration directions so many times. Did every update on everything I had in the system. I was doing exactly what you where. Hold the sticks both in for 2 plus seconds and nothing. Like you said no blank screen either and no integration. Did not see or understand anything about the roller will holding the sticks in, but importantly it works !! YES finally
4.1 Entering the menu
At this point the integration menu is closed so you can't accidently configure any parameter. To open the menu, move the Rudder stick to the right and Aileron stick to the left and hold for over 2 seconds. Once the menu is opened, you will see <READY> message. Now you can release the sticks and you are ready to set all the parameters.
