What is the reason is not more possible the altitude limit
Dr.Fleming
Sounds good thank's, will wait at the moment with the dowgrade, because I will miss the adjustable altitude on
Return Home! :idea:
ZeXx86 wrote:Yes, you can downgrade at any moment.
I think we will have solution. With a negative range of the channel that will activate it user can define the altitude limit level.
In this way you can engage it at any moment for same altitude limit and at the same time use same altitude and at the same time define it anytime at the field.
