ZeXx86 wrote:Thanks for the video.
It is really very strange.
Did you tried to enable Extended signal processing, just for test?
Also did you checked if cyclic is without any movement on the ground when motor is running? (without blades)
I know that bigger Goblins have little bit problems with rotor heads in some cases and it was nearly impossible to fix the problem. It is caused by imbalance that is created when rotor is spinning. Oscillations on the video are very same as when something is not balanced.
Can you check if there is any play in the mainshaft?
Thanks for your reply, no i didnt check Extended signal processing but did run the heli without blades and all was ok.
mainshaft is all good, no play.
Regards Alan
