Spirit GT and 9745 Satellite wiring
ExCCHP
Thank you. This does help.
From what I read of the 9747, it has an internal antenna which needs to be mounted away from CF. Since the frame is CF the only place I see to mount it would be on the boom. Not a fan and don't like the look.
Do thing I could use a 4651T as a Satellite and plug it into the SLRX2 port on the 6610?
ExCCHP
I did originally have a 4651T wired in to the Spirit via Sat2 as per the Spirit instructions. The problem was that when the signal switched over to the 4651T, I lost telemetry. There is atleast one other person that tried the same thing with the same result. Strange as they are both telemerty receivers.
Next may try wiring it directly to the 6610 to see how that works.
Something just occured to me. Would the 4651T need to have the telemerty configured and set up first in order for the telemerty to work? Maybe that's why I lost telemerty when the signal switched over. Hmmm, that makes sense to me. So how would that be accomplished. Possibly re wire it to the Spirit via Sat2. Rebind it. Then unplug the primary 6610. Then in the NX10 select Telemerty Auto Config.
Does any of this sound correct or am I off base yet again...lol?
ExCCHP wrote:Thank you. This does help.
ExCCHP wrote:I did originally have a 4651T wired in to the Spirit via Sat2 as per the Spirit instructions. The problem was that when the signal switched over to the 4651T, I lost telemetry. There is atleast one other person that tried the same thing with the same result. Strange as they are both telemerty receivers.
I think that you can put also the 4651T into the AR6610T, then you have not the problem that you loose telemetry by swtitching to the 4651T -
I had the same problems if I tried to put another SLRX2-Receiver to the SAT2 Port of the Spirit or using two 4651T one in Ele/Pit/Ail and Rud and the other put in the SAT2 port -
Here is the only way to go to put the SRXL2-Satellite into the AR6610T that you dont loose telemetry -
Best Regards
ExCCHP
That is extremely helpfull, thank you.
So you did not have to configure telemetry with the Sat then? Simply with the Primary 6610 only and telemworked when system switches to the 4651T Sat?
Is that correct?
ExCCHP wrote:That is extremely helpfull, thank you.
Is that correct?
no there is no need for extra configuration...
The only downside is that you must trust the connection from the 4651T to the AR6610T -
Maybe you can shield up the antenneas from the AR6610T to check the functionality that the 4651T can take over without signal loss - I have tried that not because I have trusted the connection from the 4651T to the AR6610T -
Best Regards
ExCCHP
Perfect
Will give that a try.
Thanks for your help. Much appreciated
