Ethos 1.5.8 update / Spirit Ethos integration
Hello senaka,
great !
Yes the downgrading was not a fun - I had also had back-ups :shock: -
What performance problems are there ?
I haven't noticed any problems with normal operation yet - do you know how that manifests itself?
Matthias
nano-tech
I give up, for me integration won't work.
spirit 2 downgrade to 3.6.1
R8 Receiver connected via fbus to the spirit (activated fbus in spirit unit and in receiver settings)
tryed ethos 1.5.6, 1.5.7 and 1.5.8
no integration :?
Hello nano-tech,
have you tried to downgrade to ETHOS 1.4.17 ? This version will also work - Try it !
and/or
What configuration do you have, ESC, FBL, receiver and transmitter ?
I will help you out if its possible -
Matthias
senaka
Mattes61 wrote:Hello senaka,
great !
Matthias
Hi Matthias,
The following is what I came across:
https://github.com/FrSkyRC/ETHOS-Feedba ... ssues/3925
Hello senaka,
thank's for the hint !
The only lua I have is the lua-script from Spirit Integration and that runs only when the heli doesn't fly...
The question if this is noticeable in the normal flight with an heli including telemetry -
I'll look into this again in another forum, maybe someone can answer this there -
Matthias
nano-tech
Mattes61 wrote:Hello nano-tech,
and/or
Matthias
Hello Matthias,
i don't want to downgrade ethos, that's not what I want
my hardware:
spirit 2 (FW 3.6.1)
FrSky X20S (Ethos 1.5.9 actually)
R8 Archer Receiver with f.bus connected to the spirit fbl
ESC is an hobbywing 100A
regards
Hello nano-tech,
I understand you 100% - we will see if there is a bug in ETHOS or the script needs to be updated -
Matthias
we will update the Lua script to make it work with the latest EthOS.
Hello Tomas,
that sounds great !
Thank's a lot !
Matthias
LuHa
Yesterday I created an issue at github:
https://github.com/FrSkyRC/ETHOS-Feedba ... ssues/4083
