[SOLVED] Banks - Futaba 14SG
hrjrkr
Thanks for replying. Your English is a lot better than some of the people I know here in the USA.
I tried reading the radio manual but could not understand it.
I will try it when I get home from work.
Thanks again,
Joe
hrjrkr
Works great icare. Thank you for your help.
Maybe Thomas should put that in his Futaba Transmitter Setup Guide!
Great, we will update the Futaba Guide soon.
keeny
How does it work then ? i did as you said and i have sg in the middle position so bank 1 is set to stabilization mode.
logic done on idle up 3 sh...........so in the software it changes to hf mode .............ok with you so far, but hitting the idle up 3 switch doesn't activate bail out ....or what am i doing wrong .....i need a drink of cider
keeny
OK o there is no bail out in stabilization mode..........................just stable or not ...............is that it ?
Coming back to this things have changed.
