No Rudder Servo Movement in normal flight mode.
Oh, I guess that the problem is in Function Assignment.
You can see that your Gyro Gain is increased by 50% which is defined in Function Assignment.
With 0% there it should work as you wish.
FrankFuss
You must make the following changes on the Jeti Servo Setup screen in order to have the Gyro Gain percentages on the Spirit Diagnostic tab match the Gyro Gain perentages on the Jeti Gyro settings screen. At least this worked for me.
Servo Setup:
Servo: Gyro Gain
Subtrim: 4%
Max +: 78%
Max -: -78%
Malc1
Thanks guys,exactally it. :)
I've now done both of these things and the gains in the transmitter now match up with the Spirit software and both Heading Lock.
Do I need to use the tab labled Tuning (Gyro sens.) at all?
What about Gyro gain in throttle hold?
FrankFuss
Great, I am glad you got it working. It looks like john2kx responded to your other questions in the Jeti Helifreak forum.
Malc1
Yeah thanks for your help :D
