Servo's go crazy when saving unit
Jman841
Ok,
Test 30 is not working so well. It started out great. The open log had no issue. But when I tried saving changes, the first time it worked perfect. the Second time it lost control to the tx, then i saved a 3rd change and it started to spool up the motor.
Hmm, could you retest it with test28, please?
I am afraid, but there should be everything same, but hopefully it is not same.
Jman841
I retried Test 28. It is much more stable than test 30 but after about 15 different changes I was finally able to get the tx to stop working.
I will test further with Test 29. Test 29 may be the one htat works 100% of the time since it is resetting the protocol each time.
Jman841
Test 29 is near perfect. The only issue is sometimes after a save there will be a delay where the Tx will not work for 2-10 seconds than it will start working again.
Test 28 was almost there but finally, after many attempts, I got it to not work.
Ah, good.
I can make link resetting faster, if it is too delayed.
Jman841
ok awesome, i'll try this one now.
Does the link resetting happen only during the software usage? I would assume that would not be a good thing during flight. Is it ok to fly with any of these tests?
Jman841
Test 31 seems to be working well. There is a slight delay sometimes for the reset and I had 1 hangup that was about 4-5 seconds but then it worked perfect again. Most saved changes were completely seamless. Nothing to be too concerned about
This can happen only if your TX will send such invalid data (it will behave like dead TX).
But In test32 I've added rather little security control, that it can be resetted only if it is connected to the software.
It should be also even faster in resetting.
Yes, you can fly with these FWs without any problem.
http://spirit-system.com/dl/fw/test/spi ... test32.bin
Jman841
Alright! Seem's pretty good.
Works perfect but about once in every 10 tries it will hang up for about 5 seconds. Then it will reconnect and all is good again.
Everything else seems to be working well.
