Devo 7
datamedic
Tail servo is 620 should i use 333h?
Yes, 333Hz is good for this servo.
Rudder Delay should be at 10 to achieve better results.
datamedic
You were correct by setting the rudder latency to 10 jn the servo to 300hz made the diference.
I got a very very small tail move and imidiate recovery on very hard pitch ups and down
Thanks guys, great support and unit
Perfect,
you are welcome!
datamedic
ZeXx86 wrote:Perfect,
you are welcome!
Yeap tweaked settings a little more and tail is solid rock no matter what. Only issue now is that when i hit rescue the heli is not going straight up. I checked the swash is level and the heli is initializing on flat surface
Anything else to try?
Coco66
datamedic wrote:Only issue now is that when i hit rescue the heli is not going straight up. I checked the swash is level and the heli is initializing on flat surface
How many degrees of error?
Can you tell me which firmware version do you have and if you are moving with the helicopter after initialization? (before flight).
datamedic
hello
i have the latest firmware
i have tryed both 1)power up and flight imidietly after init without moving the heli and 2) power up , let it init on the table and move it to flight sight 10 feet away for flight
Coco66
datamedic
i would say about 10 to 15
