Stabilisation mode.
scrambled
Great ideas!
I guess my old Futaba T7C will hold me back?
No priorities or something like that in my old TX. :(
ZeXx86 wrote:You can still set priorities in your transmitter or set the behavior so that Rescue can be active always when some switch is engaged.
If you want to use only one channel for everything, you can unassign Gyro Gain and set a static values. Then only by changing Banks you can activate Rescue/Stabilisation/normal flight.
snowflake wrote:I have a similar arrangement, but I added a couple of mixes so that, when I hit the "PANIC" momentary switch, it immediately forces Bank 1 (Rescue bank) AND Stabi to ON (or, negative gain; depending upon which method you are using.)
The mix frees me from having to throw the Bank switch, first, then hit the rescue switch.
Michael
